Rick6922
Jan 13, 2019Luminary
does anyone no what this means?
just updated to new firmware on the xbox1x [DoS Attack: ACK Scan] from source: 199.16.156.58, port 443, Sunday, January 13, 2019 15:36:04 [DoS Attack: ACK Scan] from source: 199.16.156.75, port 4...
- Jan 13, 2019
That IP belongs to Twitter. Something from Twitter is trying to access or do something. Do you have any linked accounts with Twitter or do you have a Twitter account on the console?
Rick6922
Jan 16, 2019Luminary
Yes,downgrading to v1.0.0.20 made it more stable. The NG tech support people install the new FW there selfs through teamveiwer. they checked everything I guess.its not a modem issue . according to them its the new FW. lol. is any one getting the new FW to running smooth for more than 2 days? what short time it runs without disconnecting the internet[about 5 mins] its 10 times better connection with the new ping assist. bummer right.
Jan 16, 2019Guru - Experienced User
Ok, thanks for confirming this. Ya seems to be a FW issue. Glad NG is working on it.
