matthewd88
Nov 14, 2018Initiate
does having the xr500 connected to to the ont box give issues
should having the xr500 connected through the ont from verizon effect the geo filter or anyinthing on the xr500 ? just curious cause i just hooked it up through the ont way
Nov 14, 2018Guru - Experienced User
Not it shouldn't unless the ONT has a built in router.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Netduma_Jack
Nov 14, 2018NetDuma Partner
Great advice above. I'd also recommend following this Optimal Settings guide for the Geo-Filter: http://support.netduma.com/en/support/solutions/folders/16000090646
