matthewd88
Nov 14, 2018Initiate
does having the xr500 connected to to the ont box give issues
should having the xr500 connected through the ont from verizon effect the geo filter or anyinthing on the xr500 ? just curious cause i just hooked it up through the ont way
matthewd88
Nov 15, 2018Initiate
thanks furrye38 for the options but i just put it back into the router from verizon an put it into dmz because i have tv with them an you need to have the coax hooked up to the modem in order to have your tv boxes to work an on demand otherwise all of your advice would have worked if i just had internet from them but i thank you for all the options.
Nov 16, 2018Guru - Experienced User
DMZ should work well for your configuratino needs. Enjoy.
