WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 10, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
WacoJohn
Aug 22, 2025Luminary
There is a tremendous amount of contradicting information on the 'net about XR500/READYSHARE/WINDOWS 11. Tons of users having problems on W11. Heard also of Netgear no longer supporting Readyshare. I'm pretty sure they stopped supporting the XR500 .... but Readyshare???
So, hard to get a straight answer. EVERYTHING works great on W10. W11 Pro will not even find Readyshare. Yes, SMB 1 is on. It's hard to remember but I vaguely remember it did but that would have been a long time ago. I'm at wits end with this. In your amazing wisdom, can you make any comment? You have always been so helpful. Thank you in advance.
- Netduma-FraserAug 22, 2025NetDuma Partner
ReadySHARE isn't one of our features so I couldn't say for certain if there is a specific reason it's not working on W11 BUT:
- On W11 they have it recommended now & by default the network set as public, you'll need to set this to private for sharing to work (Network & Internet > Up top where it says properties for your active connection it'll say public or private, you can click that specifically to change it - keep in mind if you use ethernet and WiFi interchangeably that one may be set as public and the other as private and vice versa)
- Network & Internet > Advanced Network Settings > Advanced Sharing Settings > Private Networks (once you've made the change) > Network Discovery On
I don't know if that will help or not, however, I use an Apple Time Capsule as a pseudo home streaming server and it only uses SMB 1.0 like ReadySHARE and everything I mentioned, as far as I am aware is what I have enabled/changed to make it work on W11.
- FURRYe38Aug 23, 2025Guru - Experienced User
Also with Win11 there has been some issues going on with Privacy settings as well:
I've noticed changes and differences between Win 10 and Win 11 and 11 being more problematic. Something about the background running services maybe failing on Win 11.
I noticed that when selected Private, other PCs on same network are need but the master PC or the viewing PC that your working on is NOT seen on the networking window. Win 10, you see ALL PCs including the master PC that your working with. MS hasn't really responded to changes in behaviors.
Yes if you have SMB 1.0 enabled in Win 11, Readyshare resources should be accessible from networking or map drive operations. How I access my 2012 era NAS devices.
