WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 10, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
WacoJohn
Aug 23, 2025Luminary
Oh yeah. Digest. Ganamens, I am 80 years old. Could not follow. I never leave my house with a computer of mine. If MS wanted to confuse someone, they did it with W11. All I know is W10, Private Always. W11PRO, what tha?????? Here is what I have right now. Tell me how to fix it please. I don't do Starbucks, libraries, public parks, Veteran's Hospitals. Someone mentioned BOTH (huh?) Nope, not me, just at home on my home network. So, please take a look and advise.
Still no READYSHARE ON W11
