WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 10, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
WacoJohn
Aug 24, 2025Luminary
Thank you. Will give that a try. Can you answer the question? ... W11. Private network on, Public on (both on) or Private on, Public off? Unlike W10, W11 CAN have both on. Sorry, but I don't get it.
