WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 10, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
Netduma-Fraser
Aug 24, 2025NetDuma Partner
If you're referring to your above screenshot, that's different but you've got all that set to allow what you want anyway, maybe too much even - as far as selecting between Private & Public there is only the two options, not a Private & Public option as far as I am aware.
WacoJohn
Aug 24, 2025Luminary
I'm giving up on W11/Readyshare. Cannot find a solution. I THINK it worked a long time ago, but not sure.
W11, unlike W10 can have both Public and Private settings. I just found this out tonight .... thank you CrimpOn
