WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 11, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
Aug 26, 2025Guru - Experienced User
Netduma-Fraser So I loaded the last current release FW on top of what I had loaded which was a beta from your site and now I'm getting this when I attempt to access the network share as i had previously did with the beta version loaded:
I disabled ReadyShare Storage and Media Server, then re-enabled both and still has not resolved. I presume there is something changed in the current released FW from the beta that I had loaded prior. Any chance you can take a look or have someone check this? Or do we need to get with NG on this? DarrenM BH_C
Netduma-Fraser
Aug 26, 2025NetDuma Partner
Apologies, the nested comments are easily missed, there is no changes from us in the latest public release and in terms of latest DumaOS I would suggest the beta. ReadyShare is a pure NG feature though so not something we've ever been involved in or changed
