WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 10, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
WacoJohn
Aug 30, 2025Luminary
What a freekin mess .... for me. There was a review I saw that said Pros and Cons of the RAX and one of the cons was 'difficult for a beginner to set up". Well, I tried and it was a disaster. It's sitting back in the pkg to go back to Amazon Monday morning. Not sure what to do. Going to return it because I don't have the expertise you do. Worn out with this Readyshare/W11 situation. Later, I will buy a RAX again, and get NETGEAR support to help me set it up. I envy your abilities ...and thank you immensely for everything. I can't mark any discussion as solved ... sorry to say. Nothing has been solved for me. Thanks again.
