WacoJohn
Aug 21, 2025Luminary
Does RAX120 replace XR500
Please forgive the bold text.
Not a router expert. Have to replace XR500 (incompatible with W11) with something as close as possible .... particularly USB ports for HDDs to be seen on home ne...
- Sep 10, 2025
This thread is SOLVED. I have requested Moderator mark it so. Turns out, XR500 Readyshare is compatible w/ W11. I just fixed it, but don't know exactly how I did it. If you are having the same problem I did, don't give up. It's all hidden in there somewhere within W11. Good luck.
WacoJohn
Sep 10, 2025Luminary
Sep 11, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- WacoJohnSep 11, 2025Luminary
Backup Indeed. Thank you. Just some back story. Went looking around on W10 and spotted an OLD .zip file. I probably created it. In there is ReadyShareConnect.exe dated 5/2/2012. That old, I did not dream that it would run on W11 but out of desperation, I closed my eyes and it ran. I was so surprised all I did was react to it (why I cant remember exactly how I fixed the problem). But I can say running that, LED me to the fix. As I recall, running it 'suddenly' let W11 show the drives and mapping worked just as I wanted.
I know forums don't like certain file types (executable) to be posted so I hesitate to provide it but here it is legitimately provided. I am assuming there are tons of people having the W11 problem I had, so good luck to those.
https://kb.netgear.com/24063/How-do-I-map-the-USB-device-attached-to-my-Nighthawk-router-to-a-Windows-network-drive
