shaanshivananda's avatar
Jul 19, 2019
Does "Region Selection" matter?
Hello Netgear Family! I just had a quick question. Under "Settings > Setup > Wireless Setup", does the "Region Selection" make a difference to my connection? If I set this to Europe, will I get co...
  • StephenB's avatar
    Jul 20, 2019
    WiFi channels are regulated in each region.  For instance, Japan allows WiFi channel 14 for 802.11b - other countries don't allow it at all.  In addition to the legal WiFi channel list, the WiFi power limit also varies by region - and sometimes those limits are set differently for specific WiFi channels.
    You should set the region correctly - ensuring that your equipment is compliant with the laws in your particular country.
