arky_4
Apr 29, 2020Aspirant
Does the Nighthawk XR500 or XR700 have max idle feature
Hi All, I’m thinking of purchasing one of the Nighthawk models either XR500 or XR700. Can I check there is a max idle setting or keep alive option? Annoyingly purchased a router which tur...
Apr 29, 2020Guru - Experienced User
What is max idle needed for?
Just curious...
- arky_4Apr 29, 2020Aspirant
apparently my router as it stands is sending user requests to ISP to disconnect. I'm told all routers should have this feature?
Just wanted to double check its there before forking out the cash!
- FURRYe38Apr 29, 2020Guru - Experienced User
Depends,
What mfr and model Modem or ONT do you have?
I have NG CM series modems and haven't see any modem to XR issues in handling with my XR450. Same HW as XR500 sans 2.4Ghz differences.
- Netduma-FraserApr 29, 2020NetDuma PartnerI've responded to your topic on the Netduma forum, including the info you provided by email. Lets continue there and for anyone that wants to follow it: https://forum.netduma.com/topic/31115-max-idle-setting/
