PiKappEY333
Aug 13, 2020Follower
Does the Nighthawk XR500 work with Express VPN?
I have had the XR500 for just over a year and a half or so and have really enjoyed it. I then purchased a subscription to ExpressVPN becuase they specifically stated that they have software support ...
Netduma-Fraser
Aug 14, 2020NetDuma Partner
You can use any VPN provider that you can get the OpenVPN configuration files from. So you should be able to get that from ExpressVPN and then use it in the Advanced Setup of Hybrid VPN.
