Toph_Bei_Fong
Jul 17, 2023Aspirant
Does the Nighthawk XR700 Router support 2 gigabit internet speeds?
Does this router support 2 gigabit speeds via ethernet? I see an option for 10G LAN SFP+ Port (10 Gbps) but I'm not sure what this is. I tried it and my internet turned off. I just had 2 gigabit int...
- Jul 17, 2023
The satellites, i.e. RBS are the remote MESH devices that are placed out in remote locations from the router, i.e. RBR.
The RBS connect to the RBR wirelessly or via ethernet: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
Toph_Bei_Fong
are there any netgear routers that use the duma os that will support 2 gig off the ethernet ports?
Jul 17, 2023Guru - Experienced User
No.
Only the RAXE500, RAX200, RAX120 and Orbi RBK850 series and RBKE960 series have multi gig WAN ports. The RBKE960 series have a 10Gb WAN port and 1x 2.5Gb LAN port.
The announced RS700 has both 10GB WAN and LAN ports.
- Toph_Bei_FongJul 17, 2023Aspirant
when is the RS700 available?
- FURRYe38Jul 17, 2023Guru - Experienced User
thanks. so what I could do with the Orbi 960 is get a 2 gigabit 8 port switch and connect it to the 2.5 gig ethernet port. Would this give me 8 2.5 gig ethernet ports? If not, is there a way to go about doing that?
