Toph_Bei_Fong
Jul 17, 2023Aspirant
Does the Nighthawk XR700 Router support 2 gigabit internet speeds?
Does this router support 2 gigabit speeds via ethernet? I see an option for 10G LAN SFP+ Port (10 Gbps) but I'm not sure what this is. I tried it and my internet turned off. I just had 2 gigabit int...
- Jul 17, 2023
The satellites, i.e. RBS are the remote MESH devices that are placed out in remote locations from the router, i.e. RBR.
The RBS connect to the RBR wirelessly or via ethernet: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
Toph_Bei_Fong
thank you. You answered all of my questions. I don't want the mesh satellite. I'll buy another Orbi and turn it into an AP like I do my other nighthawk routers, for other places in my home. I have cat6 running through my entire house.
Jul 17, 2023Guru - Experienced User
You can get the RBR with out the RBS.
