Nightman1
May 25, 2020Follower
Does the xr450 router support WAN link aggregation from a CM1200 modem?
Just wanted to make sure that the Nighthawk xr450 router supported WAN ethernet aggregation from my CM1200 modem. If so what is the setup for that?
- May 26, 2020
No. The R7960P, R8000P, Orbi AX and a few other NG model routers support LAG on the WAN side.
May 26, 2020Guru - Experienced User
