SF49FANV
Sep 08, 2019Follower
Does XR700 support PPTP, L2TP/IPSec, or OpenVPN protocols
Trying to set up ExpressVPN. ANy assistance is appreciated.
myersw
Sep 08, 2019Master
Might have better luck asking question on the correct forum.
Netduma_Alex
Sep 10, 2019NetDuma Partner
Just to make sure, you want to use ExpressVPN with Hybrid-VPN? In order to do this, you need to get an OpenVPN config file from ExpressVPN. Open this file in notepad or similar, and copy the text into the advanced section of Hybrid-VPN. Add your username and password above and you should be good to go. Let me know if it doesn't work or you need help!
