mataychic88
Jul 22, 2024Aspirant
Dont working xr500
Good day community! I have a problem with the XR500 router. Stopped working normally. It does not load to the end, does not work wifi, does not go to routerlogin and does not ping its IP address. Whe...
Jul 22, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does the Power and internet LED on the top show AMBER or WHITE?
mataychic88
The power LED at the top is yellow.
The Internet LED does not glow in any color.
Does not go to factory settings, after resetting the problem is the same.
