mataychic88
Jul 22, 2024Aspirant
Dont working xr500
Good day community! I have a problem with the XR500 router. Stopped working normally. It does not load to the end, does not work wifi, does not go to routerlogin and does not ping its IP address. Whe...
mataychic88
I connected it to directly to the outlet. I will try to access the power supply parameters through the voltage converter. I'll write back later.
Jul 22, 2024Guru - Experienced User
Make sure power adapter is connected to a 110V power supply or source. Review the Power adapter sticker for power voltage and amp input requirements.
- mataychic88Jul 22, 2024Aspirant
Original power adapter is working correctly. I tried another power supply, the result is the same - the router behaves the same way
- FURRYe38Jul 22, 2024Guru - Experienced User
Try a 30-30-30 reset on the router with out anything connected to it.
Use a phone and stop watch timer to time the 30 seconds between presses and releases:
https://www.lifewire.com/hard-reset-rule-for-routers-3971318
After the last reset, connect up one wired PC to the back of the router and see if you can get to the 1st setup wizard web page at 192.168.1.1
If this fails to bring the router to a working state, then the router will probably need to be replaced.
- Netduma-FraserJul 22, 2024NetDuma PartnerGood advice above, after the last reset if you can't access try setting a static IP on the PC with the following details
IP address: 192.168.1.100
Subnet Mask: 255.255.255.0
Default gateway: 192.168.1.1
DNS: 192.168.1.1
If you're not sure how to do this, you can check this guide: https://kb.netgear.com/27476/How-do-I-set-a-static-IP-address-in-Windows then try accessing 192.168.77.1 please and see if it works. Otherwise yes it's probably faulty.
