mataychic88
Jul 22, 2024Aspirant
Dont working xr500
Good day community! I have a problem with the XR500 router. Stopped working normally. It does not load to the end, does not work wifi, does not go to routerlogin and does not ping its IP address. Whe...
mataychic88
Original power adapter is working correctly. I tried another power supply, the result is the same - the router behaves the same way
Jul 22, 2024Guru - Experienced User
Try a 30-30-30 reset on the router with out anything connected to it.
Use a phone and stop watch timer to time the 30 seconds between presses and releases:
https://www.lifewire.com/hard-reset-rule-for-routers-3971318
After the last reset, connect up one wired PC to the back of the router and see if you can get to the 1st setup wizard web page at 192.168.1.1
If this fails to bring the router to a working state, then the router will probably need to be replaced.
