Bean731
Feb 22, 2023Follower
[DoS attack: ACK Scan] Help Please
Nighthawk XR1000 1.0.0.64_1.0.49 Windows 10 I am hoping that you could assist me with your vast knowledge in Networking. I do a little competitive gaming. Well shortly after a game noticed my la...
Feb 22, 2023Guru - Experienced User
Most of those are just the router had logging reporting what the router is designed to do in this area. Block stuff.
You'll need to so a whois lookup on those IP addresses you see there.
Most of the entries are benine.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Also recommend running www.pingplotter.com with a wired PC connected directly to your ISP modem or ONT.
