insomniak
Jun 13, 2018Guide
DOS ATTACK and DNS Failure Internet Loss
I recently purchased the XR500 Router and overall everything is running good. However over the past few days i've noticed that the internet has been cutting out once in a while for minutes at a time....
Netduma-Fraser
Jun 14, 2018NetDuma Partner
Hi insomniak, I have sent you a PM with a firmware that may potentially fix your issue.
insomniak
Jun 14, 2018Guide
I'm currently using firmware V1.0.0.325.
I'm definitely a gamer and my two sons are also gamers so that was the main reason to try this router out after reading the great reviews of NetDuma OS.
I had been using Google's DNS but am now trying out Quad9 to see if that makes any difference. I also have DDNS with No-IP.com activated if that makes any difference too.
Thank you Fraser for the firmware and i'll give it a try and report back with an update.
