MRowe
Feb 15, 2019Guide
DoS Attack
Hi,
Should I worry about this:
[DoS Attack: SYN/ACK Scan] from source: 185.97.255.42, port 7778, Friday, February 15, 2019 11:03:56 DoS Attack: RST Scan] from source: 31.25.139.237, port 42779, ...
- Feb 15, 2019
Use Domaintools.com whois feature to see what those IP addreses are coming from. Contact our ISP about changing the WAN IP address that the modem is passingthru and blocking.
It's just the router reporting what it's detecting and blocking. It's doing it's job.
Feb 15, 2019Guru - Experienced User
- MRoweFeb 16, 2019Guide
Thanks. I called ISP they said they can't do nothing with this, but you confirmed that at least my router is just doing its job. That's fine. Many thanks again.
- Netduma_JackFeb 19, 2019NetDuma Partner
Often DoS attacks are just usual Internet white noise that your router is designed to block. So as your ISP advised, this is just a good sign that the router is doing its job.
- MRoweFeb 19, 2019Guide
Thanks!
- FURRYe38Feb 20, 2019Guru - Experienced User
Ok, Enjoy. :smileywink:
