Longtooths
Apr 23, 2025Guide
DoS Attacks, RST/ACK Scan. Disconnecting from old Computer game when this happens, (Ultima Online)
I am at my wits' end, trying to figure out how to stay connected to this game when this happens. Nothing else is affected, not the Cable TV or other programs on the same computer or another computer....
Longtooths
Apr 24, 2025Guide
It looks like the game I am playing uses port 80, as does a lot of the traffic from the false flags. Therefore, when it labels this traffic as nefarious, the router perhaps momentarily stops the flow on port 80, causing me to disconnect from my old game that can not handle this action. The only thing I can think of now is replacing this router with something that does not throw false flags, like John Elway throws touchdowns. So disappointed in this router.
Netduma-Fraser
Apr 25, 2025NetDuma Partner
Add the device to Traffic Controller and allow port 80 for it and see if that works better. You could also try setting NAT to Open in WAN Settings which relaxes the firewall a little - start with this one first.
- LongtoothsApr 25, 2025Guide
Done. Monitoring over the next few days....
To be clear, in the hopes of isolating the cause, I only opened the NAT.
Worked all day until the following from the router log file, All my accounts disconnected when this happened. These IP's and the DoS attack is the same one that always disconnects me.
[DoS attack: RST Scan] from source 151.101.114.252,port 443 Friday, Apr 25,2025 20:30:00
[DoS attack: ACK Scan] from source 20.90.152.133,port 443 Friday, Apr 25,2025 20:22:09
Also, the below happened during the day, and I did not disconnect: (This repeated over 900 times, but I had to cut it because of forum rules.)
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 57699 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 48378 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 40895 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 57529 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 56738 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 42669 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 43546 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 54932 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 34589 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 33364 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 52830 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 60708 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 48489 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 55660 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 45258 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 58571 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 58244 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 50451 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 40623 Friday, Apr 25,2025 17:28:51
[DoS attack: TCP SYN Flood] from source 195.178.110.100,port 57261 Friday, Apr 25,2025 17:28:51
