JakeTech's avatar
JakeTech
Follower
Dec 19, 2023
DoS Attack/Security Breach? Please help
Model Version: Nighthawk Pro Gaming (XR500) Firmware: V2.3.2.56 OS: DumaOS - A7Legit NOT USING VPN   Backstory: About a month ago, I noticed in my router logs DoS Attacks. This had me really co...
  • Netduma-Fraser's avatar
    Dec 19, 2023
    Netgear routers are notorious for showing these logs when they're just connections you have come in contact with online. I would ignore it personally, it means the firewall blocked them
