jamses100
May 15, 2019Aspirant
Double Nat issue for Xbox One
I keep getting a NAT type moderate and UPnp not successful or double NAT on my xbox network settings, I set everything up correctly. I tried unplugging the ethernet cable that connects my xbox to the...
May 17, 2019Guru - Experienced User
What modem is the XR500 connected to? A lot of times, we find that someone is using a combo device and then a router. This causes double nat situations. here's netgears info on what double nat is.
https://kb.netgear.com/30186/What-is-Double-NAT
and how to fix it.
jamses100
May 19, 2019Aspirant
yes thats what it was, I called my internet provider and they bridged it but now what happens is that the NAT will be open for a brief time and then turn back to Double NAT
