jamses100
May 15, 2019Aspirant
Double Nat issue for Xbox One
I keep getting a NAT type moderate and UPnp not successful or double NAT on my xbox network settings, I set everything up correctly. I tried unplugging the ethernet cable that connects my xbox to the...
Oct 29, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Be sure to set a IP address reservation for the xbox ON the XR router.
Press the power button and hold it until the xbox shuts off. Reboot the modem and router. After the modem and router are back to ready. Power ON the xbox. Should have OPEN NAT.
