VillageSpaceman
Jun 28, 2018Aspirant
Double NAT Issue on XR500 and DM200 Vdsl Modem
I’m trying to setup my XR500 with a DM200(not liking this modem) for a decent Xbox One connection.
I originally setup the DM200 in modem mode only but the XR500 was unable to even detect any inter...
Netduma-Fraser
Jun 28, 2018NetDuma Partner
Not sure why you were unable to get a connection using modem mode, did you reboot both after configuring this setup? You may also require PPPoE.
For the current setup you have the easiest way would be to put the WAN IP from the XR500 System Information page into the DMZ on the DM200. Then disable UPnP/any port forwarding rules and WiFi on the DM200 and connect all devices to the XR500. This would resolve the double NAT issue. You could then either let UPnP open your NAT for your console automatically or put the Xbox into the XR500 DMZ.
VillageSpaceman
Apparently the DM200 doesn’t have a DMZ option.
I tried rebooting both in different orders and didn’t seem to help, but my Asus ac86u was able to detect the connection and go through setup..
Is there any reason the XR500 might not be able to detect the connection at all? It has an amber light so must be recognising the modem itself but when I load up any internet setup it just says no internet connection found. Couldn’t get it to work for this router until I reset the modem and set it to modem/router mode. (Netgear DM200 is a very basic modem that doesn’t even have wifi)
- Netduma-FraserJun 28, 2018NetDuma PartnerIf thats the case then it sounds like you need PPPoE, do you know if thats the case?
- VillageSpacemanJun 29, 2018Aspirant
I am currently running in ppoe on the XR500 with my username and password entered.
it doesn’t even see a connection at all in initial setup or in manual setup
- Netduma-FraserJun 29, 2018NetDuma PartnerOkay so it's all working now and you have a connection?
