Josh93
Jan 04, 2021Aspirant
Double NAT issue xr500 with nighthawk m2
Hello, I recnetly moved out to the country side and was fortuinte enough to get 100mbs/25mbs via a mobile hotspot router through a local provider. I currently have MR2100 set up as an IP passthro...
Netduma-Fraser
Jan 04, 2021NetDuma Partner
You will need to put the WAN IP from the XR500 System Information page and enter this into the DMZ on the MR2100, you can see where the DMZ function is by using the manual here: https://www.downloads.netgear.com/files/GDC/MR2100/MR2100_UM_EN.pdf
Then you should have an open NAT.
- Josh93Jan 05, 2021Aspirant
Netduma-Fraser thank you for the suggestion.
I attempeted to do that, however once the settings were saved on the Nighthawk MR2100 the WAN IP on the Nighthawk xr500 changes.
Do I need to turn off DHCP when doing this?
Do I need to set a static IP on the XR500?
- Netduma-FraserJan 05, 2021NetDuma PartnerYou can keep DHCP on, on the XR in Internet Setup just switch it over to static - it will use the same details already and then that should prevent it changing and keep the DMZ active.
