Josh93
Jan 04, 2021Aspirant
Double NAT issue xr500 with nighthawk m2
Hello, I recnetly moved out to the country side and was fortuinte enough to get 100mbs/25mbs via a mobile hotspot router through a local provider. I currently have MR2100 set up as an IP passthro...
Josh93
Jan 05, 2021Aspirant
Netduma-Fraser thank you for the suggestion.
I attempeted to do that, however once the settings were saved on the Nighthawk MR2100 the WAN IP on the Nighthawk xr500 changes.
Do I need to turn off DHCP when doing this?
Do I need to set a static IP on the XR500?
Netduma-Fraser
Jan 05, 2021NetDuma Partner
You can keep DHCP on, on the XR in Internet Setup just switch it over to static - it will use the same details already and then that should prevent it changing and keep the DMZ active.
