JSloan1995
Aug 13, 2019Star
Double NAT Xbox One
Xbox One is showing double NAT Strict. I have the xr500 connected to my Virgin Media Hub 3.0. How can i open my NAT type?
- Aug 15, 2019
Good to hear. Please mark your forum post as solved so others will know.
Enjoy. :smileywink:
Aug 14, 2019Guru - Experienced User
Your modem has a built in router and wifi already. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
JSloan1995 wrote:Xbox One is showing double NAT Strict.
JSloan1995
Aug 14, 2019Star
My ISP Router doesnt give me the option to put it into Bridge mode, however it does give me the option to put it into Modem Mode. Will this help?
