JSloan1995
Aug 14, 2019Star
Double NAT Xbox One
Xbox One is showing double NAT Strict. I have the xr500 connected to my Virgin Media Hub 3.0. How can i open my NAT type?
- Aug 15, 2019
Good to hear. Please mark your forum post as solved so others will know.
Enjoy. :smileywink:
JSloan1995
Aug 14, 2019Star
Ok thankyou. Im not in atm but I will try this solution when im home and let you know if it works.
Aug 14, 2019Guru - Experienced User
:smileywink:
- JSloan1995Aug 14, 2019StarI can happily say this has worked. Thankyou
- FURRYe38Aug 15, 2019Guru - Experienced User
Enjoy. :smileywink:
