alwong26
Dec 03, 2019Aspirant
double nat xr500 xbox one
im having trouble with my nighthawk on my xbox one i keep getting double nat type and once i got to go away now i keep getting strict nat. i just want some help and setting this gaming router up righ...
Netduma-Fraser
Dec 10, 2019NetDuma Partner
You'll need to put the WAN IP of the XR500 (found in System Information) into the DMZPlus option on the ATT gateway. Then see if you get an open NAT on the console network settings.
alwong26
Dec 10, 2019Aspirant
There’s no DMZplus option or at least I don’t know where to find it
I have a model : 5268acfxn
- Netduma-FraserDec 10, 2019NetDuma PartnerIt will be in the Firewall settings page and you should be able to enter it there. Page 23 of this guide should help you if needed http://www.dslreports.com/r0/download/2267100~5694a5d84811c1255c4f12556de77ead/5268AC%20Manual.pdf
