Alvarommb
May 19, 2019Guide
Double nat xr500
I have my ISP router (askey tcg-220) in bridge mode as a modem and the xr500 as a router, it’s posible that I can have double nat issues?, how can I test that?
May 19, 2019Guru - Experienced User
Open a Command Prompt (on a Windows PC that’s connected to the internet, click on the Start menu, type “cmd,” and hit Enter) and type “tracert 8.8.8.8“ to see the traceroute to Google’s DNS server. If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good
- plemansMay 19, 2019Guru - Experienced User
schumaku I got nothing. Now I'm traveling down a rabbit hole of research as I do some education :)
- schumakuMay 19, 2019Guru - Experienced User
Sorry Alvarommb for the excursion....
plemans start reading here: https://en.wikipedia.org/wiki/Carrier-grade_NAT - as more and more ISP run out of public IPv4 routeable addresses, they assign either RFC 6598 (or even RFC1918 private IP addresses). It's like a phone number where you can't call the phone number, but can only dial-out. You will understand this easily - your know-how and assistance in this community is great!
- AlvarommbMay 19, 2019GuideOk so Thais os the result of mu tracert
1 3ms 2ms 2ms 192.168.1.1
2 30ms 15ms 39ms 10.74.0.1- AlvarommbMay 19, 2019GuideOk so This is the result of my tracert
2 30ms 15ms 39ms 10.74.0.1- schumakuMay 20, 2019Guru - Experienced User
What ISP are we facing here?
Based on the latency of the 10.74.0.1 I guess it might be kind of carrier grade (or some in-house/in-building) NAT - unlikley something just away one GbE link like a cable modem/router.
Compare the IP address assigned to the XR500 WAN/Internet port with the Google "what is my IP address" (e.g. https://www.google.com/search?q=what+is+my+ip+address ) with the information visible on the router Web UI - Advanced Tab - Internet Port - Internet Address (when I have it right).
