Manuellll
May 22, 2019Apprentice
Double nat
put in the exposed host of the fritz box 7590 my modem the ip wan of the router but anyway I have the double nat how do I avoid this thing given that in gaming
- Netduma_AlexNetDuma Partner
So do you want to use the XR300 as an access point for your fritz box or do you want the XR300 to be the router, and the fritz box to just be a modem?
If the isp modem can't be bridged fully, then the DMZ on the modem will be the best only solution for using the XR router with the modem/router combo. DMZ helps wtih the double NAT issue.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
