Manuellll
May 22, 2019Apprentice
Double nat
put in the exposed host of the fritz box 7590 my modem the ip wan of the router but anyway I have the double nat how do I avoid this thing given that in gaming
Manuellll
May 28, 2019Apprentice
May 28, 2019Guru - Experienced User
You have a router at 192.168.178.1.
What is the MFr and model# of this router with 192.168.178.1? Is this the ISP modem with built in router?
- ManuellllMay 29, 2019Apprentice
è un fritz box 7590 si è questo
- FURRYe38May 29, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.This was already suggested in an initial post regarding this issue.
- Netduma-FraserMay 29, 2019NetDuma PartnerAlso your base ping is showing as very high. Would suggest you ping a different address and see what that gives you.
- ManuellllJun 02, 2019Apprentice
I could solve by putting a modem always netgear the d400 with the router xr500 but how should I configure the modem to put the xr500 correctly in cascade? then you could recommend me a modem that is fine with both the fttc and ftth since soon I'll probably get the ftth and the d6400 is no good as a modem
- Netduma-FraserJun 02, 2019NetDuma PartnerWith a modem you can just leave it as standard as all it does it pass traffic to the router
what do you mean to leave it standard?
- Netduma-FraserJun 02, 2019NetDuma PartnerAs in you don't need to change any settings on the modem, should be plug and play
- ManuellllJun 03, 2019Apprentice
I put the d6400 in modem mode only is it right or not? and maybe recommend a netgear modem that does not cost too much supporting the fttc and ftth line since I will soon switch to the ftth and the d6400 only supports fttc? I'd just need a good modem for my xr500 router that has these features, thanks
- FURRYe38Jun 03, 2019Guru - Experienced User
If you put the D6400 in modem only mode then you should be good to go there.
Check with your future ISP first to see what they support on there system for types of modems with out built in routers. They should have a list of modems to look at.
Netgears CM series are cable modems only.
Netgeard DM series are DSL modems only.
Any C#### or D#### series are modems with built in routers.
in what sense should I check if the ISP is compatible with the netgear modem? for now i am using the d6400 in modem mode only and it seems to be okay apart from the fact that the xr500 is not opening my doors with upnp just this i should fix, so can you make a specific model for ftth?
Yes check with your ISP to see what they support.
- ManuellllJun 12, 2019Apprentice
One thing that may seem trivial but the static ip for enabling game ports is not enough for me to insert it from the router or do I also have to set it on the device where I enable the ports? thank you
- Netduma_AlexJun 13, 2019NetDuma Partner
You should only have to set it on the router. If you do set it manually from the device, make sure it reflects what you've set up in the router. A conflict of settings would be a big problem.
- ManuellllJun 13, 2019Apprentice
for the moment I keep it static only from the router to the device but shouldn't the static device be too so as not to create conflicts?
It depends if the router is giving the computer the correct static IP that you set.
a question if I had to open more doors than more games to a single ip address would be a problem? Or can I quietly open the ports I want of any game?
No I think that would be fine.
Ok so I can open the doors I want at the same time and not suffer problems in the right game?
- Netduma-FraserJun 13, 2019NetDuma PartnerYou can forward as many ports as you want to a device, if you try to open that exact same port on another device thats when it will likely not let you.
assuming that I open the same port on another device but only one is online has made me or does not make me open it equally
- Netduma-FraserJun 13, 2019NetDuma PartnerThe actual port forwarding page would not let you apply the same port to different devices so that's not applicable unfortunately.
I understand but it is correct to make the port forward if the upnp does not work and above all to perform the portforward really improves the online gaming experience?
- Netduma-FraserJun 13, 2019NetDuma PartnerIf UPnP is not opening your NAT then port forwarding or DMZ will work. It’s not necessarily going to give you a better experience as it’s mostly just to ensure you are able to connect online properly.
- ManuellllJun 25, 2019Apprentice
a question about the IPs reserved by the router or manually on the device, what is the best practice to carry out and if both are used for the same device? or do you advise me to choose one of the two if so which one? I'm confused
- FURRYe38Jun 25, 2019Guru - Experienced User
Use only a reserved or static IP address per one device. Not both.
Recommended uses are for devices that don't need much router management, set static IP addresses ON devices. Devices like printers, controlllers, NAS, some phones, etc. For devices that need some router management, use reserved IP addresses for these. Devices like game consoles, some PCs and phones.
Set a default IP address pool, 192.168.1.100 to.200. Then use either side of this pool for static IP addressed devices. The pool is used for reserved IP addresses.
Manuellll wrote:a question about the IPs reserved by the router or manually on the device, what is the best practice to carry out and if both are used for the same device? or do you advise me to choose one of the two if so which one? I'm confused
