V5R1X
Mar 26, 2021Follower
Downgraded firmware to stabilize Xbox LAN-connection - Now I have an old firmware...
Hi guys, So I experienced, like many others, that the Xbox always seemed to lose connection to the XR500-router via LAN. I had the newest V2.3.2.114-firmware, but after searching a bit I found th...
Netduma-Fraser
Mar 30, 2021NetDuma Partner
Any hot fixes will automatically be included in the latest releases. I would recommend upgrading to the latest beta version and then doing a factory reset for a clean install and see whether it works: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196/jump-to/first-unread-message
