m0ngr3ll
Jan 16, 2021Tutor
Download speed halved, Upload from 18 Mbps to 1 or lower. XR500 or Vigor 130 issue?
Hello! I've had the XR500 and Vigor 130 just under a year now, a few hiccups along the way in terms of QoS but speeds have always been great (63 Down/18 Up) but within the past 3 weeks my speeds have...
Netduma-Fraser
Jan 17, 2021NetDuma Partner
Have you connected directly to the Draytek to see if the speeds are as expected? That would be the easiest way to determine if it was the router. Do that, assuming they're fine, what QoS settings are you using on the router?
Jan 17, 2021Guru - Experienced User
to also go along with what Netduma-Fraser said, do you have the Virgo130 in bridge mode? or is it still in router mode?
When speedtesting, are you using the built in app or testing through the browser?
