chadguthrie
Dec 22, 2018Aspirant
download speed
I just connected my new router with no problems however upon doing a speed test show I am getting between 60-80 mbps. When I bypass the wireless router and hook my computer directly to my spectrum m...
Dec 26, 2018Guru - Experienced User
What FW is currently loaded?
chadguthrie
Dec 26, 2018Aspirant
I am connected to an Arris 1602 modem and my service is through spectrum. I have updated the firmware on the router.
- FURRYe38Dec 26, 2018Guru - Experienced User
Have you factory reset the XR router and set up from scratch and walked thru the setup wizard on the XR router. I would also power OFF the ISP modem for 1 minute then back on then reset the XR router and go thru the setup wizard....Use a wired PC as well.
