chazzy2501e
Jul 22, 2022Tutor
Downloading from Steam Cripples all other web traffic.
As the title, before I purchased an XR500, downloading games using steam would see a slowdown on internet responsiveness for me and the household but only noticeable not annoying. Now with the XR50...
- Jul 22, 2022That is exactly what QoS is designed to prevent so I would highly suggest using it, take a look at our optimal settings guide to get started: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Netduma-Fraser
Jul 22, 2022NetDuma Partner
- chazzy2501eJul 24, 2022Tutor
Sorry, but this hasn't solved my issues. The main steam machine (this PC) now downloads more slowly even if no other device is in use..
When other devices are used the huge delay is still present...?
So on my dumb router steam dl at around 8.4MBs but other devices can surf just fine AND the steam download slows down somewhat, everything is good.
On the XR500 with QOS set to 70% download and upload (of benched internet speed) (always mode) The steam machine is always slower (than maximum) now capped at 6.4MBs but other devices are crippled with 500Kbs of throughput for 2-3 seconds then around 25mbit.
Then if you re-do the speed test the same behaviour occurs. I used my iphone se2020, a quest2 and the firestick4k. same behaviour.. very slow for a few seconds then it picks up. (this doesn't occur on the dumb router)
I'm using fast.com with retry on the other devices. (through respective browsers) stopping steam downloads there is NO 2-3 seconds of 500kbps slowness. (although it does trend up, the test starts immediately and starts at 10+Mbps) Notably more performant.
What should I look at to improve this behaviour? As it stands I loose maximum download speeds for the heavy downloads and incur an unacceptable delay before being allocated some bandwidth for others.
The steam downloading PC is the only wired device.
quest2 has exclusive use of 5ghz (for airlink usually)
others use 2.4ghz
cheers
- Netduma-FraserJul 24, 2022NetDuma PartnerCongestion Control by design does limit your speeds based on the percentage you set to ensure downloads etc can't saturate the connection and cause you to lag. 70% is a recommended starting point but it doesn't work for everyone so we encourage people to experiment with the percentage to find what works best for them. As you want higher speeds try higher than 70% to see if it gives you a better balance. What is the model of the modem/router the XR is connected to and are ALL devices connected to the XR?
- chazzy2501eJul 25, 2022Tutor
its connected to the bt hub (i think they call it a hub6) I've got the XR500 as the DMZ client. The XR500 handles NAT upnp dhcp dns is passed to the bt hub. All devices connected to the XR500, 1 wired PC (steam PC), quest 2 on 5ghz (exclusive for airlink), all others on 2.4ghz
Although the XR500 is behind a NAT already, it is a DMZ client so all external traffic should go to it. (specify MAC address of the XR500 to the BT hub)
I've disabled QOS as it seems to do little of help.. The QOS does seem to portion a slice of bandwidth by ensuring the steam PC doesn't saturate the entire bandwidth but the other devices still suffer a long delay for their web requests.. so the reserved bandwidth isn't made available to the other clients in a timely fashion.
What I'm having a hard time understanding that my old dumb router just handled this as I'd expect. I still can use my old router (a 3 year old AC wifi router from plusnet) using the same setup as the XR500. (as the BT router has had it radios disabled and I don't care for or trust my ISP)
btw I am using hybrid VPN (so it has a VPN connection made but the single client isn't active during testing)
