chazzy2501e
Jul 22, 2022Tutor
Downloading from Steam Cripples all other web traffic.
As the title, before I purchased an XR500, downloading games using steam would see a slowdown on internet responsiveness for me and the household but only noticeable not annoying. Now with the XR50...
- Jul 22, 2022That is exactly what QoS is designed to prevent so I would highly suggest using it, take a look at our optimal settings guide to get started: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Netduma-Fraser
Jul 22, 2022NetDuma Partner
chazzy2501e
Jul 24, 2022Tutor
Sorry, but this hasn't solved my issues. The main steam machine (this PC) now downloads more slowly even if no other device is in use..
When other devices are used the huge delay is still present...?
So on my dumb router steam dl at around 8.4MBs but other devices can surf just fine AND the steam download slows down somewhat, everything is good.
On the XR500 with QOS set to 70% download and upload (of benched internet speed) (always mode) The steam machine is always slower (than maximum) now capped at 6.4MBs but other devices are crippled with 500Kbs of throughput for 2-3 seconds then around 25mbit.
Then if you re-do the speed test the same behaviour occurs. I used my iphone se2020, a quest2 and the firestick4k. same behaviour.. very slow for a few seconds then it picks up. (this doesn't occur on the dumb router)
I'm using fast.com with retry on the other devices. (through respective browsers) stopping steam downloads there is NO 2-3 seconds of 500kbps slowness. (although it does trend up, the test starts immediately and starts at 10+Mbps) Notably more performant.
What should I look at to improve this behaviour? As it stands I loose maximum download speeds for the heavy downloads and incur an unacceptable delay before being allocated some bandwidth for others.
The steam downloading PC is the only wired device.
quest2 has exclusive use of 5ghz (for airlink usually)
others use 2.4ghz
cheers
