kbryant
Aug 13, 2020Tutor
Drop packets
Hello All, I am experiencing a problem with packet loss. The question I have is there any way to see if I have maxed out the bandwidth on my network?
- Aug 13, 2020If you go to the Network Monitor page you can see how much usage is being used right now.
Netduma-Fraser
Aug 13, 2020NetDuma Partner
How are you measuring the packet loss exactly? Are you talking about data cap or whether your bandwidth is saturated/congested at that moment?
- kbryantAug 13, 2020Tutor
I am talking about whether or not my bandwith is saturated or congested at the moment. Thanks for replying.
Netduma-Fraser wrote:
How are you measuring the packet loss exactly? Are you talking about data cap or whether your bandwidth is saturated/congested at that moment?- Netduma-FraserAug 13, 2020NetDuma PartnerIf you go to the Network Monitor page you can see how much usage is being used right now.
If you go to the Network Monitor page you can see how much usage is being used right now.I thought so, but I wasn't sure. Now am I am. Thanks for your help.
