JasonWarren
Mar 25, 2019Follower
Dropping Connection When Gaming Online
I have been in contact with my computer manufacturer and my ISP and both have tried for months to fix my issue with no luck.
I can be browsing the internet all day long with no issues but as s...
Mar 25, 2019Guru - Experienced User
What FW is currently loaded?
Is QoS and AntiBuffer Bloat enabled? Try disabling these and test again.
Set a IP address reservation for the PC ON the router.
Try a factory reset and setup from scatch. This time, just test gaming using default settings on the router.
- Netduma-FraserMar 26, 2019NetDuma PartnerDo you own the R6700? If so I would suggest posting here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk as this area of the community is for NPG routers which runs different software.
