Alewi
Feb 07, 2020Apprentice
Dsl stats throw xr700
Greetings, Is there anyway I can check the dsl states throw xr 700 ? Like crc errors, Snr margin..etc. I can do it on my ISP's modem/ router when it is in router mode, but as I set it up as dsl modem...
- Feb 08, 2020There is no way to do that through the XR700 unfortunately. The modem will still be accessible but its IP will probably have changed once you put it into modem mode. Look up the model of the ISP modem/router and you should be able to find what it has changed to.
Netduma-Fraser
Feb 08, 2020NetDuma Partner
Alewi
Feb 08, 2020Apprentice
Thank you Fraser.
I can log in into the modem, but unfortunately can't open the dsl stats page, cuz it is somehow hidden page, not original one and works exclusively when the modem in router mode. Thank you for your answer (:
