josephinelcajon
Nov 22, 2020Tutor
Dual WAN Failover
Hello, I have three ISP providers that one or the other seem to constantly go down. I am tired of switching from one to the other and having to reboot everything. I am currently using the XR500 r...
Nov 23, 2020Guru - Experienced User
I believe the edge router x line supports failover/dual wan.
might be something to check out.
https://xenappblog.com/2016/cheapest-dual-wan-router-for-failover/
- josephinelcajonNov 23, 2020TutorI actually read about that one and looked it up. I had the same problem though not knowing if it can give me a full gig speed through it. I ended up rolling the dice and bought the Netgear router off ebay. Now its a double gamble will it even work on top of will it give me the speeds. THANKS!
- plemansNov 23, 2020Guru - Experienced User
Hope it works well for you!
Didn't consider the option of used. New its a spendy purchase.
- FURRYe38Nov 24, 2020Guru - Experienced User
The Edge Router X does support near 900Mpbs WAN to LAN speeds. Just has to be enabled is all. It works.
