Beard444's avatar
Beard444
Follower
Jul 14, 2023
DUMA geo filtering issue with BattleEye and Rainbow Six Siege
Does anyone get this message below when launching R6 Siege? I came to the conclusion that it is due to geo-filtering because I do not get the message when I enable fast search in the geo-filtering op...
  • Netduma-Fraser's avatar
    Jul 15, 2023
    Depending on what your settings are it may be being forced to use some other servers other than its preference which could account for the delay, makes sense with fast mode on you don't experience that. When you're unable to connect have a look at the map and check for anything blocked, you may need to add that to your allow list.
