prince-horus
Jul 24, 2020Tutor
duma os 3.0
Hello, can you do something about the update to duma os 3.0 of my netgear XR500 router, indeed in view of all the purchases made towards your brand, I am among the last not to have received this upda...
prince-horus
Jul 24, 2020Tutor
Oh I'm sorry I don't know where to post my email, but the attempt to download this firmware is very long, apologize so
Netduma-Fraser
Jul 24, 2020NetDuma Partner
You're definitely not the last, lots of people have signed up for the beta. People are being invited frequently, keep an eye on your emails as it could come at any moment.
- prince-horusJul 30, 2020Tutor
hi Fraser,you know why the delay is so long and you know why the people are impatient to try duma os 3.0,i've contourned the issue of the duma os xr500 on a line fiber gigabit by my own purchases. i know that the issue doesn't the fault of hardware or soft but i would use the duma os 3.0 to see if my line is perfect because all the sites or programmes tell me that i've 0.2 ms of jitter on a ping of 4ms. How it's possible the route to play is in exemple 50 ms and a friend has a router quadcore 2.4 ghz with out geofiltre and his ping is 30ms.the issue is his line fiber has a baseping 6ms and in game 30ms without geofiltre,i have 4ms and in game 50ms with geo filtre,can u explain me if it is the infrastructure of the FAI the issue and maybe it's not possible to find the gaming paradise.
i am only a passionnate of game that not understand why there is 6 years,we should only plug a ps3 on wifi and it was magic and today with fiber ,it's unplayable except you find ways ,sorry for the long text...prince
- Netduma-FraserJul 30, 2020NetDuma PartnerIt's entirely possible your ISP routing isn't as good which is why the ping is higher, or that you're connecting to different servers. Try using Ping Assist (PA) to find the lowest possible server and then force that - it may be mis-located that's why it would be best to use PA to find it.
