edgarg37
Nov 13, 2021Tutor
DUMA OS App load issue
having this issue again it will not load please help: this happened again is there a permanent fix? I cannot open Device manager or QoS Error: This Rapp is not loaded yet, please try again in a m...
edgarg37
Nov 13, 2021Tutor
- michaelkenwardNov 14, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers. - Netduma-FraserNov 16, 2021NetDuma PartnerGo to the System Information page, go to the Rapp panel and click the option icon (3 horizontal lines) then change the retries to 5 then reboot the router and wait 2 minutes before accessing.
Also if you're on the new Safari update that forces HTTPS which isn't great for accessing the interface so would recommend using another browser if you encounter any more errors.- edgarg37Nov 16, 2021TutorStill not working even after I changed it to 5 and update safari
- Netduma-FraserNov 16, 2021NetDuma PartnerDid you reboot and wait 2 minutes before accessing? That's the most important part as it restarts the loading of the Rapps and allows them to load properly
- NetBulldogDec 21, 2021Aspirant
I have been living with DUMA OS App load issue for a year, I have tried everything referenced on this site and worked with customer support – nothing has worked. It looks like the only way to solve the issue is to purchase another brand of router. Which I will reluctantly be forced do soon if I do not find a solution.
- michaelkenwardDec 22, 2021Guru - Experienced User
NetBulldog wrote:
I have been living with DUMA OS App load issue for a year...
If you need help with DumaOS, follow the earlier advice in this ageing discussion and try the place where they discuss gaming routers.
Re: DUMA OS App load issue - NETGEAR Communities
- Netduma-FraserDec 22, 2021NetDuma PartnerNetBulldog if you've truly tried everything that has been suggested then probably the best thing to do would be to reupgrade the firmware using TFTP - this bypasses the boot process and any issues there, then once complete do a factory reset. Once a reset is done wait 2 minutes before accessing the router.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
