edgarg37
Nov 13, 2021Tutor
DUMA OS App load issue
having this issue again it will not load please help: this happened again is there a permanent fix? I cannot open Device manager or QoS Error: This Rapp is not loaded yet, please try again in a m...
edgarg37
Nov 13, 2021Tutor
Netduma-Fraser
Nov 16, 2021NetDuma Partner
Go to the System Information page, go to the Rapp panel and click the option icon (3 horizontal lines) then change the retries to 5 then reboot the router and wait 2 minutes before accessing.
Also if you're on the new Safari update that forces HTTPS which isn't great for accessing the interface so would recommend using another browser if you encounter any more errors.
- edgarg37Nov 16, 2021TutorStill not working even after I changed it to 5 and update safari
- Netduma-FraserNov 16, 2021NetDuma PartnerDid you reboot and wait 2 minutes before accessing? That's the most important part as it restarts the loading of the Rapps and allows them to load properly
- edgarg37Nov 16, 2021TutorCorrect I waited 5 minutes just in case and it did not work
