edgarg37
Nov 13, 2021Tutor
DUMA OS App load issue
having this issue again it will not load please help: this happened again is there a permanent fix? I cannot open Device manager or QoS Error: This Rapp is not loaded yet, please try again in a m...
edgarg37
Nov 13, 2021Tutor
NetBulldog
Dec 21, 2021Aspirant
I have been living with DUMA OS App load issue for a year, I have tried everything referenced on this site and worked with customer support – nothing has worked. It looks like the only way to solve the issue is to purchase another brand of router. Which I will reluctantly be forced do soon if I do not find a solution.
- michaelkenwardDec 22, 2021Guru - Experienced User
NetBulldog wrote:
I have been living with DUMA OS App load issue for a year...
If you need help with DumaOS, follow the earlier advice in this ageing discussion and try the place where they discuss gaming routers.
Re: DUMA OS App load issue - NETGEAR Communities
- Netduma-FraserDec 22, 2021NetDuma PartnerNetBulldog if you've truly tried everything that has been suggested then probably the best thing to do would be to reupgrade the firmware using TFTP - this bypasses the boot process and any issues there, then once complete do a factory reset. Once a reset is done wait 2 minutes before accessing the router.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
